1992 Chevy Truck WILL NOT START
BILL SORY
  • 1992 CHEVROLET TRUCK
  • V8
  • 4WD
  • 175,000 MILES
THE TRUCK QUIT WHILE DRIVING. WILL NOT START. CHARGED BATTERY NO HELP PUT BATTERY CHARGER ON BOOST AND TRUCK STARTED. LET IT IDLE AND TURNED OFF WOULD NOT START. REPLACED BATTERY NO START. CHECKED FOR FIRE AT PLUG AND OK MAY BE WEAK DON'T KNOW WHAT IT IS SUPPOSE TO LOOK LIKE. FUEL PUMP COMES ON AND GAS TO ENGINE. THE ING MOD HAS BEEN REPLACED LAST YR ALONG WITH A NEW FUEL PUMPTHE STARTER SPIN THE ENGINE. COULD A WEAK COIL BE CAUSING THIS
Thursday, April 2nd, 2009 AT 9:11 AM
JDL
  • 16,098 POSTS
If your TBI can you see the injectors spray gas, with the engine cranking? Is there an injector pulse?
If I use a spark plug as a tester, I break the ground electrode off, if the spark will jump between the center electrode and plug body, I consider it ok. You can get a cheap spark tester at the autostore, adjust the gap wide, see if the spark will jump.
Thursday, April 2nd, 2009 AT 9:32 AM
