1990 Chevrolet Truck Clutch Slipping
GOTJUICE
The clutch pedal started moving to the floor when depressed. I replaced the clutch master and slave cylinders. After I bled the system it has worked fine for 5 days. This morning the weather was warm and the clutch is engaging at the top of the pedal and will slip if you get on it in taller gears than you need to be in. The pedal was about a inch down when I installed the cylinders. I have bled them again and no air. Is there a adjustment i just don't see. Also i pumped up the clutch and held it down to bleed them.
Tony Brothers
Jan 9, 2006 at 5:59 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like you need a clutch
Jan 10, 2006 at 9:57 AM
Suggested Repair
Replace the clutch.
Conversation Summary
On a 1990 vehicle, the clutch pedal began going to the floor. The owner replaced the clutch master and slave cylinders and bled the system, after which it worked for about five days. The clutch then began engaging near the top of the pedal and slipping under load in higher gears. Further bleeding found no air, and the owner asked about adjustment. The expert advised that the clutch needs to be replaced.
