1988 Chevy Truck Truck will not start
WDBOWLING
  • 1988 CHEVROLET TRUCK
  • V8
  • 11,800 MILES
We just put a brand new fuel pump, fuel relay, and fuel filter on our 1988 Chevy 1/2 ton 2wd 350 5.7 truck. The fuel pump will pump out gas but we can not get the truck to start. IF you use gas on the throttle injector it will run. We are out of ideas and any help is greatly appreciated.
Friday, January 22nd, 2010 AT 5:11 PM
Check the fuel pressure with a gauge to make sure the fuel pump is producing the correct fuel pressure and also check if the injectors are pulsing
Friday, January 22nd, 2010 AT 5:34 PM
WDBOWLING
Ok thanks for the response. Ok we have gas going to the injectors but the injectors are not letting any gas come out. Is this an electrical problem or? Thanks again
Friday, January 22nd, 2010 AT 5:58 PM
Check if the injectors have power if so -could be a problem with the injector/s driver circuit in the computer or its not getting an ignition references signal
Friday, January 22nd, 2010 AT 6:09 PM
Related Engine Not Running Content
