Pilot bearing
MODECKER
  • 1988 CHEVROLET TRUCK
6 cyl Four Wheel Drive Manual
What will happen if I didn't put a pilot bearing when I putt the clutch back together
Wednesday, April 22nd, 2009 AT 7:51 PM
SQM
  • 6,383 POSTS
Without the pilot bearing you will have internal damages to the transmission as the vehicle gets driven. It can damage the clutch along with the input shaft, as well as other components.
Best option would be to install the bearing right away.
Here is a helpful guide on replacing the pilot bearing:
https://www.2carpros.com/articles/pilot-bearing-replacement
Sunday, November 14th, 2021 AT 5:53 PM
