1997 Chevy Truck Engine Sputters and shakes
153,000 MILES • V8 • 4WD • AUTOMATIC
TOBRYAN
Engine sputters and shakes during accelleration and idles roughly. Noticed at first in wet weather. Had the distributor cap replaced. Didn't change anything. I changed the spark plug wires and it still didn't help. I tried to start it yesterday and it wouldn't start for me. It will try to turn over then it sounds like it is choking and then boggs down and stops. The next step I was going to take after the spark plug wires was to change the EGR valve, but I don't want to do this if it is something else. Any advice or help is greatly appreciated.
Dec 26, 2008 at 12:27 PM
RACEFAN966
  • 5,029 POSTS
Ok have you cleaned the mass air flow sensor yet? I would get some mass air flow cleaner and clean it first then if that don't change anything then we test the coolant temp sensor. Thanks and get back to me have a great day.
Dec 26, 2008 at 1:56 PM
TOBRYAN
I cleaned the MAF Sensor and I got it to start, but the sputtering during acceleration is still happening, and it almost cuts out during idle. I noticed a knocking noise when I turned it off and I opened the hood and noticed the top radiator hose jumping and hitting some engine parts causing the knocking noise. Also, the heat does not get very hot anymore.
Dec 30, 2008 at 6:00 AM
RACEFAN966
  • 5,029 POSTS
You are low on antifreeze and it was boiling over that is why the top hose was doing that. You need to get the radiator full and you will have heat too. It may be getting to hot so fix that and get the radiator full and let me know how it runs and we will do a test on the mass air flow meter then.
Dec 30, 2008 at 1:54 PM
