I have a 250 with Rochester 1bbl Monojet carb recently rebuilt. The truck will crank up fine, idle fine (out of gear) and run at speed fine. The one thing it will not do fine is accelerate from idle well. Even sitting in Park, if I give it some gas it will bog down, sputter and try to cut off. When I try to put it in gear, just that load is enough to bog it down and cut off. I have checked/replaced all the vaccumm lines leading into the carb, set the timing (vaccumm loose) at 4 degrees BTDC and replaced points, plugs, plug wires, and ignition coil.
Any ideas where to go from here, stumped.
SPONSORED LINKS
Saturday, August 22nd, 2009 AT 6:05 PM
