1997 Chevy Truck Sputtering???
1997 CHEVROLET TRUCK
135,000 MILES • V8 • 4WD • AUTOMATIC
JACORNBREAD
When I am going 50-60 mph and start to add a LITTLE (up to 200rpm) gas, not going into OD, my truck startes to jerk. It feels like it is stalling or sputtering. It only happens at this time.
I have recently replaced the plugs and wires and keep up the fluid maintenance. I cant really tell if it is engine or the drive train. I never noticed it until after the plugs were changed.
I have checked to see if the plug wires were loose and had the fluid in the transmission checked. All looks good.
Jan 22, 2008 at 12:49 AM
BIGALC
Check your oxygen sensors. If one or more is bad this could be causing the problem.
Jan 25, 2008 at 3:35 PM
BAMA BRIAN
i had the same problem ,change the fuel filter under the driver side door its inside the frame
Jan 26, 2008 at 5:07 PM
  • 110,244 POSTS
Hi Alicia, we never got a final reply for that post. It is from 2008. Let me know the year, make, and model of the vehicle and the engine size. Also, let me know what is happening and I'll do my best to help.
Take care.,
Aug 21, 2023 at 12:51 PM
