1987 Chevy Truck no power to fuel pump
SHINE498
  • 1987 CHEVROLET TRUCK
  • V8
  • 4WD
  • 300,000 MILES
Hello. This truck had been running. All of the sudden it stopped. It will turn over. We don't hear the fuel pump clicking on. We dropped the tank and replaced the fuel pump. The pump still doesn't appear to be getting any power. The fuel filter is new.
Talking to the neighborhood auto parts store they have suggested replacing numerous parts :-) Could you by chance help us narrow down what might be the most likely causes?
Thank you so much!
Tuesday, May 19th, 2009 AT 8:38 AM
RACEFAN966
  • 5,029 POSTS
I would do some checking first as you can replace parts till your broke. So have you checked to see if there is power at the pump. If no power then check the fuse and the fuel pump relay as these are you most likely causes.
Tuesday, May 19th, 2009 AT 9:39 AM
