1986 Chevy Truck
DEREK71
  • 1986 CHEVROLET TRUCK
1986 Chevy Truck
How do I remove the front upper and lower ball joints. A pickle fork is not working
Wednesday, June 11th, 2008 AT 10:29 AM
DOCFIXIT
  • 18,828 POSTS
You may need an air hammer with a ball joint bit. The fork you have is more for tie rods. You could try heating with a torch if no air hammer is avaiable.
Good Luck
Wednesday, June 11th, 2008 AT 10:40 AM
RHALL77
  • 3,361 POSTS
Or put the nut part way back on and use a hammer and hit the side of the housing or hit the nut right on. This usually pops it loose.
Wednesday, June 11th, 2008 AT 11:18 AM
