1987 S-10 chevy pickup 167,00 miles 4 cyl.
ROBERT LASSEY
The drivers side front tire sits at an angle.It also hangs a bit lower when the front end is off the ground.I have checked all the joints,ect. nothing is loose.My daughter slid nose first into a ditch @ 3ft. deep a short while back. I suspect the stabilizer bar is bent. How can I determine this ?
Feb 16, 2007 at 1:09 AM
CHEVY22
  • 1,375 POSTS
take it in for an aligment , if something is bent you will find out for sure then
thanks
Feb 19, 2007 at 4:07 AM
CHEVY22
  • 1,375 POSTS
thanks for the update ,
Feb 22, 2007 at 9:40 PM
