1982 Chevrolet Caprice Low Ride Height
VFREDIE213
hi, I have a concern, My 82 chevy caprice is kind of low, I wanted to know how to raise the car up so I can put bigger rims on it. Do I only have to change to bigger shocks, or what else do I need to adjust so it can be higher.
Jan 24, 2006 at 5:04 AM
MVANNESSJR
  • 223 POSTS
:roll:
Yes... Bigger rims... That's all the world needs... :wink:
Usually proper shocks, struts, and springs will do the trick. Depending on how "high" you want to go. Keep in mind you may need to calibrate your speedometer after putting large rims on the vehicle because it will most likely throw it off.
Jan 24, 2006 at 5:11 PM
VFREDIE213
Well thankx for the advice I will start working on it this weekend. SO all I need is Shocks, springs and struts. Now my question how to calibrate the speedometer.
Jan 25, 2006 at 3:38 AM
Suggested Repair
Raise the vehicle with the proper shocks, struts, and springs for the desired height. After installing larger rims, calibrate the speedometer because the tire-size change will likely make it inaccurate.
Conversation Summary
The owner of a 1982 Chevy Caprice wants to raise the car to fit larger rims and asks whether bigger shocks alone are enough. The expert says proper shocks, struts, and springs are typically needed, depending on the desired height, and notes that larger rims will likely require speedometer calibration. The owner plans to proceed and asks how to calibrate the speedometer, but that follow-up is not answered.
