2004 Chevrolet Trailblazer Fuel Pump Failure Fix
But the fuel injector is located in the intake on the engine under the hood
Fuel pump is in the fuel tank
I don’t see connection
If your fuel gauge wasn’t working correctly you may ran out of fuel!
3 years old no warranties no discount
Suggested Repair
No further repair is indicated from the injector flush. The fuel pump in the tank and the injectors on the engine are separate, so the flush did not cause the pump failure. If the gauge was erratic, the sender may have been damaged with the pump and should be replaced; a faulty gauge can also lead to running out of fuel.
Conversation Summary
A 2004 Chevrolet Trailblazer had its fuel injectors flushed during a dealer visit for a transmission concern that could not be duplicated. Weeks later it sputtered and hesitated, was towed in, and the dealer replaced the fuel pump and recommended replacing the fuel-level sender because the gauge was erratic. The owner asked whether the flush caused the pump failure. The expert said the injectors and in-tank pump are not connected, so the flush was unrelated, and noted a bad gauge could have allowed the vehicle to run out of fuel. The vehicle was out of warranty with no discount offered.
