2002 Chevrolet Trailblazer Rear Wiper
GMC
MBOWLING
I have a 2002 Trailblazer and the rear window wiper and washer will not work. When I press the button for the washer I hear the noise but nothing happens. What could be cause of my problem? Is it the relay?
Thanks.
Nov 14, 2006 at 2:15 PM
LSUSSEL
  • 252 POSTS
It could be that the wiper is stuck or the motor might have gone bad and the noise you hear is the pump pumping out washerfluid. Have you tried slowsy moving the wiper by hand to see if its not caught somewhere?
Nov 28, 2006 at 3:42 PM
MBOWLING
No I have not tried to move the wiper by hand. I will give that a try. If the motor has gone bad, how expensive is it to have one installed?
Nov 29, 2006 at 1:15 PM
LSUSSEL
  • 252 POSTS
Well the price of the motor can be anywhere from 100 - 300 dollars plus labor. Here is a way to tell if its the motor. Instead of pushing the wash botton as if you were going to clean the rear window, hit the botton that turns on the wiper as if it were raining - if you hear no noise, then its the motor, if you hear noise then it is something else you would need to look into... let me know..
Nov 30, 2006 at 1:53 PM
MBOWLING
When I turn the window wipers on I hear nothing. It must be the motor. Thanks for helping out. I will have to look into getting the motor replaced.
Dec 2, 2006 at 12:43 AM
Suggested Repair
Gently move the rear wiper by hand to check for binding. With the wiper switch on (not the washer), no motor noise indicates a failed rear wiper motor. Replacement motors typically cost about $100–$300 plus labor.
Conversation Summary
A 2002 Trailblazer owner reported that the rear wiper and washer did not work, though the washer pump made noise. The expert suggested checking whether the wiper arm was stuck and distinguishing pump noise from motor operation. Turning the wiper on produced no noise, so the owner concluded the rear wiper motor had failed and planned to replace it.
