1997 Pontiac Sunfire Wipers Won't Park
GMC
EMILYANDJERSEY
1997 pontiac sunfire : my wiper blades dont go back down to original position when turned off. any ideas?
Mar 20, 2007 at 12:31 PM
SERVICE WRITER
  • 9,123 POSTS
turn ignition on, turn wipers to off, disconnect the wiper switch connector. if they now park, you need a switch. If the don't it may be wiring or a wiper motor assy.
Mar 20, 2007 at 12:40 PM
Suggested Repair
With the ignition on and wipers set to off, disconnect the wiper switch connector. If the blades then park, replace the wiper switch. If they do not, check the wiring and the wiper motor assembly.
Conversation Summary
The owner of a 1997 Pontiac Sunfire reported that the wiper blades do not return to their parked position when turned off. The expert advised turning the ignition on, setting the wipers to off, and disconnecting the wiper switch connector. If the blades then park, the switch is faulty; if not, the cause may be wiring or the wiper motor assembly.
