2002 Chevrolet Trailblazer Low Voltage
https://www.2carpros.com/articles/how-to-replace-an-alternator
Cheers
Also be sure that you have a solid ground to the engine and the frame of your truck!
Nothing else besides that.
Good Luck
Any tips on how to remove the alternator?
2. Remove drivebelt.
3. Unbolt AC line mounting bracket at engine lift hook.
4. Remove the right engine lift hook and alt. mounting bolts and alternator.
5. Disconnect electrical connectors from alternator.
Suggested Repair
Treat the low charging voltage as a failing alternator: bench-test the replacement or original unit, confirm solid engine and frame grounds, and recheck battery connections. If the battery still drains overnight, note that the dealership could not reproduce it and that leaving the key in the ignition was ruled out.
Conversation Summary
A 2002 Chevrolet Trailblazer 4.2 owner reported charging voltage dropping near 12 volts, sometimes returning to 14, worse with high-current accessories, while a clamp meter still showed substantial alternator current and the battery tested good. An expert said the alternator was failing and pointed to a replacement guide. Another owner who had already replaced the alternator and battery still saw a no-charge warning; the advice was to bench-test the alternator and verify solid grounds to the engine and frame. A separate overnight battery-drain complaint was not reproduced at the dealer, and the owner said the key was not left in the ignition. Removal tips included disconnecting the battery, removing the drive belt and related brackets or lift hook, then unbolting the alternator and connectors.
