2003 Chevy Trailblazer Blower Only on High
ROBNCRYS0518
I have a 2003 Chevy Trailblazer with 96,000 miles with a V6 engine and today when I went to put on the heater, the heater would only go on when I put it all the way up to 5. It would not work on 1-4 settings. I tried this for all the fan types, AC, fan, defroster...etc. What could be causing this and how do I get this fixed? Please help!
Nov 1, 2007 at 5:51 AM
MERLIN2021
  • 17,250 POSTS
Try the blower motor resistor, on the right inside under the dash, by the blower motor. And look at your fuse panel for a blown fuse, the number 5 speed is on a diferent cucuit.
Nov 1, 2007 at 6:01 AM
Suggested Repair
Check the blower motor resistor under the dash near the blower motor, and inspect the fuse panel for a blown fuse. High speed is on a separate circuit.
Conversation Summary
The owner of a 2003 Chevrolet Trailblazer reports the blower works only on the highest setting for heat, AC, and defrost. The expert suggests checking the blower motor resistor under the dash by the blower motor and looking for a blown fuse, noting high speed is on a different circuit.
