2003 Chevy Trailblazer 4WD Grinding
SWEDENURSE
When attempting to place my 2003 Trailblazer in anything other than 2WD, I hear a grinding noise. This happens with AWD and 4WD alike. Any thoughts as to what may be the problem and what the cost of repair may be? Thanks in advance.
Tracy
Sep 1, 2007 at 1:19 AM
MERLIN2021
  • 17,250 POSTS
Your transfer case is computer controlled and if not working it is either the fuse, or it has a stored code, get the codes read! The other thing to check is the oil level, to check it you take the plug out of the case and the oil should be even with the bottom of the plug hole....fill with the same fluid as tranny, they share same fluid!
Sep 1, 2007 at 1:45 AM
Suggested Repair
Have the transfer case codes read and check the related fuse. Also check the transfer case fluid level at the fill plug; it should be even with the bottom of the hole. If low, refill with the same fluid used in the transmission.
Conversation Summary
The owner of a 2003 Chevrolet Trailblazer with 55,000 miles hears grinding when selecting AWD or 4WD instead of 2WD. The expert says the computer-controlled transfer case may have a fuse problem or a stored code, and recommends reading codes and checking that the fluid level is even with the fill-plug hole, using the same fluid as the transmission.
