FRONT
1. Support engine using lifting equipment.
2. Remove engine mount through bolt and nut.
3. Raise engine and remove mount to engine attaching bolts, Fig. 1 .
4. Remove engine mount.
5. Reverse procedure to install
REAR
1. Raise and support vehicle.
2. Support rear of engine using equipment.
3. Remove mount to crossmember attaching nuts and washers.
4. Remove mount to transmission attaching bolts, then the mount.
5. Reverse procedure to install. Tighten bolts to specifications shown in Fig. 2 .
this is procedure for non 4 wheel drive
May 29, 2006 at 6:21 AM
