2000 Chevrolet Tahoe Starts Then Stalls
When it doesn't start:
It has set for longer than normal.....
You turn the key, it cranks over a few times, starts and stalls.......
You then try to start it again by turning the key, the engine turns over, but it doesn't start......
When it is not starting after every attempt it cranks fine starts and stalls within a second or so. At times on mornings it would not start and later in the afternoon it would start up fine. On other occasions I would try to start two three days in row without it starting once. It got so bad I parked it and use it very seldom starting it only to attempt to keep my battery healthy. I had a person interested in buying it one day but I could not get it started for him to test drive. I have it at the dealer now they can not find anything wrong with it. I asked them to keep it for a few days hoping they experiance the no start. I have thought of vediotaping the occurance the next time so they can see it on tape.
If they can't solve it, post when you get it back and maybe we can try a few things when it happens and you have it.
-vats (vehecle anti-theft system) problem that may include: Key switch and cylinder lock passlock.
-faulty connector at fuel pump and or ground.
-faulty fuel pump replace with # 25314329
-fuel metering valve (part of fuel injection spyder)
-Terminals ant fuel pump relay being sread too far apart in relay box. Replace relay as well.
These are all "fixes" the fit the description of your symptoms.
Hope you finger it out.
Thanks again for your time and help.
.[/quote:16377166e3]
I don't see how either would cause an Intermittant no start.
Keep the for sale sign on it if you really intend to sell it. (be honest about it of course). You never know who would be wiling to take on the truck regardless. In the meantime, one may be interested when it does get solved.
If you fixed the problem, what fixed it?
Suggested Repair
No confirmed fix was reported. When the stall happens, check the passlock/VATS system including the key and lock cylinder, the fuel-pump connector and ground, the fuel pump, the fuel-pump relay and its terminals, and the fuel-metering valve on the injection spider. A leaking fuel-pressure regulator can also cause an intermittent no-start, usually with a strong fuel odor; a fuel filter is unlikely.
Conversation Summary
A 2000 Chevrolet Tahoe with a 5.7 engine intermittently cranks, starts, and stalls within about a second after sitting, then may start normally later. The dealer could not reproduce it. An expert listed possible causes including passlock/VATS, a fuel-pump connector or ground, the fuel pump, the fuel-metering valve, and spread fuel-pump relay terminals, and later added a leaking fuel-pressure regulator if a strong fuel odor is present. The fuel filter was considered unlikely, and the problem was not reported as resolved.
