1998 Chevrolet Tahoe Clicks No Start
AHPDRIVER
I have a 1998 chevy tahau and i have put a new battery in it and it willl not start all it will do is click ,click had the alt checked and cleaned all the cables. could it be the wrong cranking amps
Mar 8, 2007 at 12:05 AM
BOOTDOG
  • 665 POSTS
sometimes when you buy a new battery, if the battery sits on the shelf awhile it'll loose some of it's charge. try jump starting it and let the vehicle run awhile so the alternator can bring the voltage up to normal.
Mar 8, 2007 at 7:46 AM
Suggested Repair
Jump-start the Tahoe and let it run so the alternator can recharge the battery. A new battery that sat on the shelf may have lost charge.
Conversation Summary
The owner of a 1998 Chevrolet Tahoe installed a new battery, but the engine only clicks and will not start. The alternator was checked and the cables were cleaned. The expert said a shelf-stored battery can lose charge and recommended jump-starting it, then letting the vehicle run so the alternator can restore normal voltage.
