Now sometimes I have to try two or three times to get it started?
RICHROWE
  • 1999 CHEVROLET TAHOE
  • V8
  • 4WD
  • 130,000 MILES
My 99 tahoe used to start on the first click, now sometimes I have to try two or three times to get it started. Hot or cold it doesnt matter. Sometimes it starts right off and sometimes it doesnt. I have changed the fuel filter, replaced the fuel pressure regulator, (not fun). And the fuel pump module. I dont know what else to check. Because the problem seams to occur when the car is off, No codes or check engine light. What do you think?
Tuesday, October 28th, 2008 AT 7:16 PM
MASTERTECHTIM
  • 4,750 POSTS
First I would check fuel pressure when you get the extended crank. There are so many problems with these fuel pumps, thats where I look first. I find in most cases the connector on the fuel pump is melted on the gray wire or the black wire due to high resistance. There is a amp draw test you can do on the fuel pump test lead if you have a multimeter with a 10 amp dc test port on the meter. These pumps should be pulling 10 amps if its good when I find they have less than ten amps there is a problem in pump or wiring causing the problem
Saturday, June 5th, 2021 AT 2:51 PM
LOGAN424
I have a 2wd 99 tahoe I had the same issue I tried all the those things even replace fuel injectors but it ended up being the fuel pump was bugging out I dont know if thats your case as well but thats what fixed mine
DANNY L
  • 5,648 POSTS
Hello
Thanks for adding your input. Even thought the post is years old it might help someone with similar issues. Thanks for using 2CarPros.
Danny-
