2002 Chevy Tahoe Right Turn Steering
TODDTIKIUN
2002 Chevy Tahoe 4x4 with a 5.3 liter engine and 50k miles. when turning the vehicle to the left the power steering is fine. but when turning to the right it doesnt work at all.
May 31, 2007 at 8:05 PM
RUDPRO
  • 224 POSTS
I haven't run into this problem myself but I found the steering wheel position sensor, or the power steering pressure sensor could be causing the problem. Have your car scanned for trouble codes.
Jun 2, 2007 at 6:39 PM
Suggested Repair
Scan the vehicle for trouble codes, then check the steering wheel position sensor and the power steering pressure sensor as possible causes of power steering that works only when turning left.
Conversation Summary
The owner of a 2002 Chevrolet Tahoe 4x4 with a 5.3L engine reports that power steering works when turning left but not at all when turning right. An expert who had not seen this exact issue suggested scanning for trouble codes and checking the steering wheel position sensor or power steering pressure sensor.
