2002 Chevy Tahoe Steering Vibration
BULVERDE1
I am hearing a vibration under/or in my steering column. It happens when I am going around 30mph and/or if I am on a bumpy road...It sounds like it is metal on metal and I know that if I move my gear shift back and forth I can also hear the same noise....Any suggestions as to what it could be? It has about 120,000 miles on it.
Feb 8, 2007 at 12:44 PM
CHEVY22
  • 1,375 POSTS
sounds like you have the old steering shaft blues , not a big deal to do and inexpensive to pay someone to do .there was a recall but i dont know if your vehicle was in it , you may want to call the dealer and give them you vin over the phone before moving forward
good luck
jim
Feb 16, 2007 at 6:34 PM
Suggested Repair
Have the intermediate steering shaft inspected and replaced if worn. Call the dealer with the VIN first to see whether a related recall applies.
Conversation Summary
A 2002 Chevrolet Tahoe with about 120,000 miles has a metal-on-metal vibration in or under the steering column around 30 mph and on bumpy roads; the same noise occurs when the shifter is moved. The expert attributed it to a worn steering shaft, said replacement is inexpensive, and recommended checking with a dealer by VIN for a possible recall before proceeding.
