1966 Chevy Truck installing a later model tilt steering col
USA1OSU1
  • 9 POSTS
1966 Chevy Truck V8 Two Wheel Drive Automatic
I have a 66 C10 that has had the wiring butchered. I got a wiring diagram from you. Once I started tracing things down I found the wiring in the steering column completely burnt. It is a later model column and was not hooked up correctly. I went to the local salvage yard and found a pristine tilt column out of a 78 C10. I thought $50 was a great deal. Is there a quick rundown on hooking up the hazard light switch to work that was not available on the 66? Or can you point me in the right direction?Thanks for your help
Nov 6, 2008 at 3:41 AM
JAMES W.
  • 2,394 POSTS
I sent you the other diagrams. Let me see if I can find one on a '78 column and I'll fax it to you. I should still have your fax #.
Nov 6, 2008 at 4:38 AM
JAMES W.
  • 2,394 POSTS
I sent you the previous diagrams. Glad they worked out. Let me see what I can find on a '78 column and I'll fax it to you.
Nov 6, 2008 at 4:48 AM
USA1OSU1
  • 9 POSTS
Is there anything special about hooking up the hazard light and where I would need to hook up to the fuse block and how to run an extra flasher for the flashers. Thanks for your help
Nov 6, 2008 at 4:49 AM
USA1OSU1
  • 9 POSTS
Were you able to find wiring for the 78 C10 steering column. Thanks
Nov 9, 2008 at 1:29 PM
JAMES W.
  • 2,394 POSTS
I haven't forgotten you. My resource sysem has been down since Friday. I should have it up again this morning. I'll get it to you as soon as I can, Jim
Nov 9, 2008 at 9:09 PM
