have a shimmy in steering wheel at 35-45 all front end parts are tight and had align, and tires done what else can caust this problem.
Apr 19, 2007 at 10:29 AM
2CARPRO JACK
✓Experienced Mechanic
rotate tires front to back and get the same thing? 99 Tahoe im inclined to think it needs a new idler arm at minimum
Apr 19, 2007 at 10:50 AM
JHOOVE
MEMBER
had tires rebalabced align,rotated, idler,pivot bracket,pitman arm all have been done everything else is tight no movement
Apr 19, 2007 at 10:52 AM
BOBBISHOP
MEMBER
My 99 Tahoe had a similar problem. Steering wheel would jerk to left or right on bumps or rough roads. Went through everything you did. Ended up changing front shocks, which made a huge improvement.
