2001 Chevrolet Tahoe Fuel Stall
SCOTT MYERS
2001, tahoe, 5.7 with 92,831 miles. My wife had an accident about a year ago since then we have had a fuel problem. The damage to the tahoe was in the front but the brush guard took most of the impact. The hood and 2 side fenders were replaced, along with the brush guard. when driving the vehicle it will suddenly go down to around 30 to 40 mph and acts like it is not getting fuel then will stall out. We sent it to the shop where they replaced the fuel pump stating that was the problem. well the pump they put in somehow messed up the foat so it would not read any longer. The pump was replaced again and we did not have any problems again until just recently. I have had other people look at the tahoe but they are stumped on what the problem could be. When I got home last night I took it out for a test drive, when It is in park and you rev the engine it works just fine. when I put it in drive- it was very hesitant at first then I pushed the accelerator to the floor and it took off as it should. Has anyone else has this problem or know what it could be?
Mar 23, 2007 at 1:27 AM
SERVICE WRITER
  • 9,123 POSTS
These have a problem with a leaking fuel pressure regulator, I don't know if that is or isn't the case with yours.
Mar 23, 2007 at 11:51 AM
SCOTT MYERS
Thanks, I will give that a try and see if it works.
Mar 25, 2007 at 10:14 PM
Suggested Repair
Inspect the fuel pressure regulator for leakage and replace it if it is leaking. Confirm fuel pressure under load, since the pump has already been replaced twice.
Conversation Summary
A 2001 Chevrolet Tahoe 5.7 with about 92,831 miles stalls and drops to 30-40 mph as if starved of fuel, especially after a front-end accident. The fuel pump was replaced twice after a float issue, and the problem later returned; it revs fine in park but hesitates in drive. An expert noted these vehicles can have a leaking fuel pressure regulator and suggested checking that, without confirming it is the cause. The owner planned to try that.
