1999 Chevrolet Tahoe Flickering Gauges
BIGV8JOE
i have a 1999 2 door tahoe with 160000 miles on it. the problem started with a noisey fuel pump. everytime the fuel pump would whine the volts would move up. also my fuel gauge has flickering. i have replaced the fuel pump. noise has stopped but the gauges are still flickering. i had the altanater checked it was good i replaced the belt still no change. im stumped on what to do next.
Jul 28, 2007 at 4:40 AM
2CARPRO JACK
  • 11,533 POSTS
When you say flickering do you mean the lighted part or the gauges move back and forth fast?
Jul 30, 2007 at 12:59 AM
BIGV8JOE
yes the fuel gauge move back and forth real fast almost like a vibration and the volts moves back and fourth between 14 and 19 like a pulse.
Jul 30, 2007 at 7:08 AM
2CARPRO JACK
  • 11,533 POSTS
I have seen the fuel gauges do that, replaced the gauge and all was alright.The volt gauge, check with a meter for steady system voltage at the alt and at any power points.
Jul 30, 2007 at 8:56 AM
Suggested Repair
Replace the flickering fuel gauge, which has resolved similar rapid gauge movement. For the volt gauge pulsing between about 14 and 19 volts, verify steady system voltage with a meter at the alternator and at other power points.
Conversation Summary
A 1999 Chevrolet Tahoe had a noisy fuel pump, a flickering fuel gauge, and a volt gauge that moved when the pump whined. Replacing the pump stopped the noise, and the alternator and belt checked out, but the gauges still flickered. The fuel gauge vibrates rapidly and the volt gauge pulses between 14 and 19 volts. The expert recommended replacing the fuel gauge and confirming steady system voltage with a meter at the alternator and power points.
