flickering gauages please help
BIGV8JOE
i have a 1999 2 door tahoe with 160000 miles on it. the problem started with a noisey fuel pump. everytime the fuel pump would whine the volts would move up. also my fuel gauge has flickering. i have replaced the fuel pump. noise has stopped but the gauges are still flickering. i had the altanater checked it was good i replaced the belt still no change. im stumped on what to do next.
Jul 28, 2007 at 4:40 AM
2CARPRO JACK
  • 11,533 POSTS
When you say flickering do you mean the lighted part or the gauges move back and forth fast?
Jul 30, 2007 at 12:59 AM
BIGV8JOE
yes the fuel gauge move back and forth real fast almost like a vibration and the volts moves back and fourth between 14 and 19 like a pulse.
Jul 30, 2007 at 7:08 AM
2CARPRO JACK
  • 11,533 POSTS
I have seen the fuel gauges do that, replaced the gauge and all was alright.The volt gauge, check with a meter for steady system voltage at the alt and at any power points.
Jul 30, 2007 at 8:56 AM
