I put it in 4WD Low and Now it will not shift back to 2WD or 4WD high?
Dec 25, 2009 at 9:40 AM
✓Experienced Mechanic
Have you tried backing up when changing? If so and it still doesn't work, you need to check if the 4wd actuator on the transfer case is getting power. If it is, chances are it is bad.
Let me know what you find.
Jan 5, 2010 at 2:13 AM
