2006 Chevy Tahoe Front End Grinding/Popping
52,000 MILES • V8 • 2WD • AUTOMATIC
RHD68
When I turn sharp, I hear a grinding/popping noise in the front end. Is this a bearing problem already? I can't seem to find anything loose. If it is bearings, is there an internet how-to guide that you know of, or should I buy a repar manual.
May 29, 2008 at 2:04 PM
LEGITIMATE007
  • 5,121 POSTS
I believe that you have a cv joint problem. and sometimes its cheaper to replace the entire axle then it is to do the cv joints alone. so look into labor charges. a book would be the best way to show you how to do it if you want to do it yourself
May 29, 2008 at 4:47 PM
