2003 Chevy Tahoe V8 Two Wheel Drive Automatic Unkn miles
Had recently replaced the starter and found the negative wire corroded, cleaned and tightened. Still had to have a jump to get past starter just clicking. Engine started, several times just fine. Then clicking again. Checked connections, tightened, started fine. Now, it won't click at all, even with a jump. Good battery, 14v showing on dash. Dash lights up, but nothing at starting position. What happened? I changed the terminal end on the bad wire, could it be the battery? It won't even turn with a jump though?
It's a friend's truck, trying to help. He already paid someone to replace the starter and can't afford further expenses right now. Thanks for any help you can provide.
SPONSORED LINKS
Tuesday, March 10th, 2009 AT 11:47 PM
