2002 Chevy Tahoe Engine "knock", Maybe Knock Seno
10,700 MILES • V8 • 2WD • AUTOMATIC
HEFFE
I own a 2002 Tahoe with 107,000 miles. It is the Big V-8 5.3. Around 95k miles the Service Engine Light. I downloaded the faults and had 2 faults for running Rich and 1 fault for a miss fire. I have replaced all 4 o2 sensors and now the only fault is the miss fire. The engine itself works great after a 15 minute warm up period (during the warm up period, RPM's flux betweeen 200 and 1500) It has actually died a couple of times. It also has a "surge" like feel to it at stop signs and red lights. I was wondering does this sound like a possible set of bad knock sensors or should i be looking somewhere else?
Dec 9, 2008 at 3:51 AM
  • 110,246 POSTS
Hi:
Based on your description, it doesn't sound like the knock sensor. It sounds more like a throttle position sensor. When you get the random misfire code, are you able to identify which cylender it is?
Dec 16, 2008 at 11:47 AM
