1997 Chevy Tahoe Cold engine knock
145,000 MILES • V8 • 4WD • AUTOMATIC
CAM-MAN
My truck has a knock when I first start it but only when the ambient temp is below about 40 degrees. All summer long , I have no knock.
Jul 19, 2009 at 2:10 PM
  • 31,937 POSTS
Hi there,
what engine oil are you using? Have you checked the oil pressure with a mechanical gauge when cold?
Mark (mhpautos)
Jul 19, 2009 at 6:56 PM
CAM-MAN
I have not put a mechanical gauge on it, but it's a good idea, and I will do it. I have been using Quakerstate. What are your thoughts on synthetics like Mobile 1? I also heard of 4 others with these same symptoms, and they were told it's a normal amount of piston slap. Any thoughts?
Jul 22, 2009 at 8:21 AM
  • 31,937 POSTS
Hi there,
The syn oil may start an oil burning issue, the pressure test is the key just now, if that is ok, i would be thinking the piston slap may be the cause.
Mark (mhpautos)
Jul 22, 2009 at 10:26 AM
