Been a long time since the tune up kept a car from starting. If they didnt use the updated pump and wiring for your truck when they did it the first time, it could very well need to be done. Did they use an OEM pump, nothing else is worth the time to install. If they do it, have the relay and th efuse replaced, the GM pump module comes with the connector and fuse, you will need to buy the relay seperatly
SPONSORED LINKS
Tuesday, May 4th, 2021 AT 12:19 PM
