1995 Chevy Tahoe
RONNIE40
  • 1995 CHEVROLET TAHOE
Electrical problem
1995 Chevy Tahoe 100000 miles
I just changed the fuel pump, fuel filter and relay. It ran for a while and died. No fuel is getting through the line and they are open. What else can I check?
Saturday, December 1st, 2007 AT 10:54 PM
PEAR69
  • 1,482 POSTS
Sounds like the electrical connection at the pump may be bad or corroded. This is all too common. Check the ground at the fuel pump. Make sure it is not corroded. If you remove the fuel pump relay you will notice a wiring diagram on it. This diagram has terminal numbers on it. If you jump out terminal 85 to 86 this will send 12 volts directly to the fuel pump. Try this and test the voltage at trhe pump. Be sure you have a good ground.
Saturday, December 1st, 2007 AT 11:53 PM
