2001 GMC Yukon Front Driveshaft Locked
DPJ
I have a 2001 Yukon XL, 5.3 4x4, with the auto transfer case, 73000 miles. When 2 Hi is selected, the front driveshaft is still locked in gear even though the front axles are disengaged. You can shift into 4 Lo and 4 Hi and Auto 4 Wd, but the front driveshaft never stops turning in 2 Hi. Any suggestions? Thanks :(
Feb 27, 2007 at 12:21 AM
CHEVY22
  • 1,375 POSTS
there are a few things it could be
1 switch
2, encoder motor on transfer case , have someone help you , run th vehicle , have someone under the vehicle near the transfer case and start hitting buttons to ses if you hear the motor switching hwe tthe buttons are pressed and get back to me
thanks , jim
oh and if you are happy with the info please leave some feedback we all donate out time here helping people for free
Feb 27, 2007 at 2:30 PM
DPJ
I had to take the Yukon into the dealer to check a couple of other items and was informed that this particular transfer case never disengages the front driveshaft. Strange? I have checked a couple of other year GM models that do disengage the front driveshaft, but the tech guy assures me that mine is performing as designed.
Mar 16, 2007 at 4:39 PM
Suggested Repair
With a helper shifting modes, listen at the transfer case for the encoder motor actuating. If it does not switch, check the mode switch and encoder motor. A dealer also said this transfer case is designed to keep the front driveshaft turning in 2HI.
Conversation Summary
The owner of a 2001 Yukon XL with an automatic transfer case reported that the front driveshaft stays locked and turning in 2HI even though the front axles disengage, while 4HI, 4LO, and Auto 4WD still shift. An expert suggested checking the mode switch and encoder motor by listening for the motor while the buttons are pressed. The owner later reported a dealer said this transfer case is designed never to disengage the front driveshaft.
