1997 GMC Suburban No Fuel Pump Noise
UK-SUBURBAN
Hey,
I was driving my 1997 5.7 GMC Suburban yesterday, stopped off and when i got back in it 5 mins later it wouldn't start! There is plenty of fuel in it, the fuel relay is clicking but the fuel pump doesn't seem to be making any noise.....how loud are they, should i hear it from under the tank? Is the an inertia switch fitted to the 97 gmc's? Could this of been activated some how? Any ideas please HELP? This car is a US model shipped to the UK where its hard to gain info on them.....
Thanks Ryan
Sep 15, 2007 at 11:01 PM
SERVICE WRITER
  • 9,123 POSTS
No inertia switch. Take a funnel and put in the filler neck. HAve someone turn the key to "on" and have your ear up the the megaphone (funnel). IF nothing try rapping on the bottom of the tank. That may jar it temporarily to work.
IF you need one get the delphi.
There is a connector that needs to be replaced when changing the pump:
https://www.2carpros.com/forum/automotive_pictures/30961_connector_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_mitchel_19.jpg
You can read about the TSB through here:
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Sep 15, 2007 at 11:10 PM
Suggested Repair
There is no inertia switch. Listen through a funnel in the filler neck while the key is turned on. If silent, rap the tank bottom to temporarily free the pump. If replacement is needed, use a Delphi pump and replace the associated connector; a related TSB is available.
Conversation Summary
A 1997 GMC Suburban 5.7 would not restart after a short stop. The fuel relay clicked but the pump made no noise, and the owner asked whether an inertia switch could be involved. The expert said there is no inertia switch, suggested listening through a funnel in the filler neck and tapping the tank, and recommended a Delphi pump plus connector replacement if the pump must be changed.
