1998 GMC Suburban Fuel System Quote
NOOM
  • 7 POSTS
what is the ballpark figure for the replacement of the fuel filter, fuel pump, and fuel relay? im being charged $850.00.
car wont start. electrical anylasis was done, no success. firestone states the factory fuel pump, relay, and filter need to be replaced.
need to know if im being taken advantage of.
thx
Feb 28, 2007 at 5:46 AM
CHEVY22
  • 1,375 POSTS
all prices and times are gm,
the fuel pump relay 1s $12.00 and .05 in labor
the filter is 18.18 and .05 labor
the fuel pump is 151.30 and 2.0 hrs in labor
by my calculations on labor here based on 100.00 per hr 350.00 in labor and 181.48 in parts thats roughly 531.00
the parts i listed are oem gm and the price is reatil not wholesale meaning the shops pay less and you could go to anydealer and buy these parts at that price ,
firestone is probably using aftermarket parts which i do not reccomend especially the fuel pump , price sounds high to me , but calculater their labor rate by the times ai gave you and it should get you close and find out what brand parts they are using , non gm is a nono
thanks , jim
oh and if you are happy with the info please leave some feedback we all donate out time here helping people for free
Feb 28, 2007 at 6:10 AM
NOOM
  • 7 POSTS
i called and he said it a delphi fuel pump and also stated that it was a cert gm part. is this accurate?
thx for all the help
Feb 28, 2007 at 9:49 AM
CHEVY22
  • 1,375 POSTS
yes all sounds ok
good luck
thanks , jim
Feb 28, 2007 at 10:56 AM
Suggested Repair
Compare the $850 quote with GM book figures: relay about $12 and 0.5 hour, filter about $18 and 0.5 hour, and fuel pump about $151 and 2.0 hours, roughly $531 at $100 per hour with retail OEM parts. A Delphi pump described as a certified GM part is acceptable. Confirm the shop labor rate and part brands, and prefer OEM or certified GM parts over generic aftermarket, especially for the pump.
Conversation Summary
The owner of a 1998 GMC Suburban that will not start was quoted $850 to replace the fuel pump, filter, and relay after electrical analysis did not find the cause. An expert priced OEM GM parts and labor near $531 and said the quote seemed high, particularly if non-GM parts were used. The owner later confirmed a Delphi pump claimed as certified GM, which the expert said was acceptable.
