Chevrolet Suburban No-Crank Intermittent
SOLSANDERS
Chevrolet Surburban 1197 2500 [radio, a/c, tape deck, trailer brake added but cut, backup signal added] 95,000
I had one seriouis front-end collision when the radiator, etc., was replaced but this has developed two years later.
Intermittently, with no patern I can discern the ignition will not turn over the starter motor. It happens under all weather conditions, no particular geographic location, etc., sometimes twice in a few hours [parking, stopping the engine, trying to restart], sometimes not for several days, even a week.
When it happens, all the guages light up and indicate no problem. All the rest of the electrical system seems to be working -- windows, horn, lights, radio, a/c.
The first time it happened, AAA told me to shift into neutral and it started. It has not done that since.
I formerly tried to jiggle the switch, the steering, turn it off and on, etc., subnstituted the second set of keys, etc., but not with any effect.
But I have learned that if I just wait it goes ahead normally -- sometimes it will connect in a couple of minutes but usually it takes five to 10 minutes. It then proceeds normally. I have no difficulty on the road driving once it has started up.
Jul 24, 2007 at 2:48 AM
2CARPRO JACK
  • 11,533 POSTS
you are going to need a meter or test light . When it wont start, test the small wire at the starter for 12 volts when key is in the crank position.Might just be a bad starter
Jul 24, 2007 at 4:24 AM
ROTORY-POWER
  • 9 POSTS
HI, This sounds like the same problem that I am having and was just wondering if you have been able to find the solution? Thanks!
Sep 10, 2007 at 7:24 PM
Suggested Repair
When it will not crank, use a meter or test light to check the small wire at the starter for 12 volts with the key in the crank position. If voltage is present, the starter may be faulty.
Conversation Summary
The owner of a Chevrolet Suburban reports an intermittent no-crank condition with no clear pattern. Gauges and other electrical systems work, and waiting several minutes usually allows a normal start. An expert advised testing the small starter wire for 12 volts during cranking and said a bad starter is possible. No confirmed repair was reported.
