no fire to the engine
CHEVROLET
KAT774
I have 97 chevy suburban 4x4 k1500 with 95,000 miles on it. I have replaced my fuel pump, fuel filter, ECM, and fuses for the fuel system and Im still not getting the truck to start. can you help me narrow the problem down. I have also had my transmission replaced along with the drive shaft
Jan 24, 2007 at 4:09 AM
INDYUKE
  • 416 POSTS
Check fuel pressure at the fuel rail atop the engine, and check that each spark plug is getting spark.
Also check to see if the check engine light is on. If it is on, it indicates there is something awry with an emission related component.
Jan 24, 2007 at 1:19 PM
JEFTFIELDS
  • 74 POSTS
even though you dont say if you have spark or not, check the distibutor shaft for side movment, and also check modul in dist.
Jan 24, 2007 at 1:31 PM
