Chevrolet Suburban Cranks No Start
Suggested Repair
Confirm the engine has spark as well as fuel while cranking. If both are present, make sure the distributor is tight, then compare rotor position with the harmonic balancer timing marks. If the marks are far off, the timing chain has likely slipped and should be replaced. Prolonged cranking may also have damaged the starter separately.
Conversation Summary
The owner of a Chevrolet Suburban says the starter cranks but the engine will not start, despite fuel being present. Recent misfires and power loss led the owner to suspect timing or a slipped timing chain, while a shop said the starter failed after prolonged cranking caused smoke. The expert says year, engine size, and mileage are needed, then advises checking spark. With fuel and spark during cranking, timing should be checked by aligning the distributor rotor with the number 1 cap tower and comparing the balancer marks; a large error indicates a slipped chain, while a loose distributor is another possible cause.
