chevy suburban 2002
RRAN65
the ignition wont turn when you put the key in the bells go off and the security light blinks but the key will not turn .
May 17, 2007 at 1:26 PM
BOOTDOG
  • 665 POSTS
look at the key to see if it's worn. if so, and you have a spare try that. if you still have no luck then the key cylinder is worn and will need to be replaced.
May 17, 2007 at 1:44 PM
