Door Locks Not Working?
HMAC300
  • 48,601 POSTS
No it may be the key fob auto parts can check to see if they are working otherwise a mechanic has to scan the system for codes to find the problem.
Friday, September 25th, 2020 AT 10:23 AM (Merged)
MELONIE BROWN STOKLEY
  • 2001 CHEVROLET SUBURBAN
  • 135,000 MILES
My remote door lock/unlock does not work. The remotes are good, I had them checked. What modular controls the door locks? I even reprogrammed the locks and they still do not work.
SATURNTECH9
  • 30,869 POSTS
The body control module controls all that. How did you try reprogramming the remotes?
ROXXY129
  • 2000 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 135,000 MILES
My door locks will not operate. The relay clicks and the lights flash on the outside and the horn activates, but the doors will not lock. It started when it was a rainy day, and it corrected itself when I turned the front and rear heater on high and let it cook for an 1/2 hour. But after a wet day the problem returned. Now the heat wot help it! I replaced all the relays and pulled apart all the plugs and lubed them w/ switch grease. I checked all the fuses. How much does the Body Control Module play a role in this circuit? I am at wits end. Almost! Please reply.
DOCFIXIT
  • 18,828 POSTS
H
BCM does it all but if your sure the relay clicks then BCM is doing it's job. Can you lock doors from master panel? Will key unlock the doors?
Let me know
Thanks for donate
ROXXY129
The key will unlock the door, but when you try any door including the drivers control, all you hear is the relay click. When you push the lock on the key remote, the horn beeps and the lights flash, but no lock.
DOCFIXIT
  • 18,828 POSTS
O. K. As I understand not able to lock doors via key or master control but relay clicks, horn etc.
Need OHM meter pull lock relay find terminal # 30 probe then, may need to unbolt fuse block, find two Gray/ black wires probably next to each other. Place other probe on one of them What does it read?
If open then wire faulty.
ROXXY129
Thanks I will try this and let you know, can you send me a wiring diagram?
ROBBOB3000
  • 1999 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 114,000 MILES
The swith to lock and unlock the doors will not work on the driver or passenger side. The remote will work for the door locks but not the interior switch. Also half of the lighted station numbers on the factory radio are out. I checked the fuses, they're all ok except the 20amp for the transfer case keeps blowing. I'm not quite sure whats the problem.
  • 109,885 POSTS
Hi:
First, you need to have the driver's side switch checked. It feeds power to all. Next, to repair the lights on the radio, you will need to take it to a stereo shop to have it taken apart and repaired. Finally, the it sounds lilke you either have a short going to the transfer case or the actuator motor is bad. Disconnect the plug to the transfer case and see if it still blows the fuse. If it does, you have a short. If it doesn't, there is a problem in the actuator.
94DESSUBURBAN
  • 1994 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 312,000 MILES
I have 94 2500 suburban 6.5 TD. The vehical Runs great. Starts right up and batteries are new. When every I hit any accessory other then the radio my guages al drop off, my glow plugs light up, Rear wiper turns on. It almost seems like the unit isnt getting enough power. For example if headlights are on or blower fan is on low, my power window seem to have little to no power to for up and down. Door locks wont work either. If I put my blower on medium or high it dims out and turns off and once off it comes back lit up. Do you suspect a faulty ground to the fuse box or maybe an ECM or ignition Switch. Thanks For you Help.
  • 31,937 POSTS
Hi there,
I think you are right on the money with this one, I would be checking over all the earthing points, make sure that the battery cables are clean and tight, start here.
Mark (mhpautos)
