2002 Chevy Suburban Intermediate steering shaft
98,000 MILES • V8 • 4WD • AUTOMATIC
PABLOMTZ
Would like instructions to replace the intermediate steering shaft.
Nov 16, 2009 at 9:47 AM
KNOWYOURAUTO
  • 113 POSTS
1) Secure the steering wheel in place with the wheel straight ahead, using a bungee cord so it will not rotate freely. 2) In the foot well by the pedals remove one 15mm? bolt to the column.
https://images.2carpros.com/forum/automotive_pictures/435113_steeringShaft1_1.jpg
Push the shaft forward to disengage.
https://images.2carpros.com/forum/automotive_pictures/435113_steeringShaft2_1.jpg
Finally remove the 15mm bolt under the hood to the opposite end of the shaft.
https://images.2carpros.com/forum/automotive_pictures/435113_steeringShaft3_1.jpg
The nut for this bolt is normally oblong in shape and will not unthread as easy as others. To install, reverse procedure. Good luck,
Nov 17, 2009 at 5:20 AM
