A tune-up is always a good idea. Also, use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one.
Your security system, could cause a start and stall issue? Also, if you have the spider fuel system, the fuel poppets may need to be cleaned? You can try injector cleaner in the gas tank, don't know if it will help?
SPONSORED LINKS
Sunday, February 21st, 2010 AT 1:21 PM
