ABS light comes on
FADL
  • 1998 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 183,000 MILES
I just had my front brake pads and rotors replaced. Now my ABS light comes on and then goes off and sometimes my brakes grab and pull (hard to stop whe this happens). My truck is now hard to start when it is warm (good cold start) - what seems to be the problem?
Wednesday, July 30th, 2008 AT 12:19 PM
MERLIN2021
  • 17,250 POSTS
I don't know what the ABS would have to do with the truck being hard to strt, but the shop may have dinged a ruluctor, or wheel sensor during the brake job, have them re-inspect thier work and fix what they did wrong. First step is to read the codes with a scanner that can read "C" codes. This will point you to the affected are of the ABS system. As for the starting problem, check the vacuum hoses near the master cylider, see if the shop maybe knocked one off.
Wednesday, March 17th, 2021 AT 7:00 PM
