2000 Chevy Suburban ABS Light and Brake light
112,000 MILES • V8 • 2WD • AUTOMATIC
SCOTTRHANES
Periodically, the ABS light and the Brake Light light up on the instrument panel while the car is running. If i shut the car off the lights turn off and may or may not turn on. There is nothing that is consistent to why they turn on?? Its pretty random. I m wondering if this is a sensor or is this somthing major with the ABS system.
Jan 11, 2008 at 3:16 AM
2CARPRO JACK
  • 11,533 POSTS
Might just be a bad wheel sensor or something like that. No need to go to the dealer, just a shop that has the equipment to scan the ABS. There will be a code in the PCM, that will point us in the right direction
Jan 11, 2008 at 11:45 PM
