1996 Chevy Suburban 1996 Suburban Stalled. Won't start
5KEEPERS
  • 1996 CHEVROLET SUBURBAN
  • V8
  • 155,000 MILES
I thought it has water in the gas, I cleaned the tank completely (removed and cleaned!). It had a SMALL amount of water and no contaminats.
It will not start unless I pour gasoline down the throttle body. And it will run as long as I pour gasoline into it.(Carefully).
Fuel line pressure is almost non-exsistant.I do not have apressure gauge. Very very little gasoline "spits out" when I press the inline valve.
Any ideas.
Thank You!
Saturday, February 16th, 2008 AT 5:29 PM
MASTERTECHTIM
  • 4,750 POSTS
Check the gray wire at the fuel tank sender for power, also look carefully at the plug to see if there are any melt marks, if you have power and no melt marks then replace your fuel pump.
Saturday, February 16th, 2008 AT 6:18 PM
