1995 Chevy Suburban stalling, no pick-up, dies between gear
NEOTIA
  • 1995 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 203,000 MILES
I've changed plugs and wires, coil, fuel filter and checked the oil for the milky texture of coolant being present. The oil was fine. What else could cause this OTHER than the throttle position sensor?
Sunday, November 29th, 2009 AT 4:13 PM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Sunday, November 29th, 2009 AT 4:48 PM
