I got a 94 Chevy 350 motor it starts fine and runs fine but when I excelerate and give it a lot of gas it bogs down
Apr 20, 2013 at 1:01 AM
HMAC300
✓Experienced Mechanic
scan for codes and check fuel pressure first
Apr 20, 2013 at 1:17 AM
MPLSBADBOYZ
MEMBER
fuel pressure is fine anything else
Apr 20, 2013 at 1:33 AM
HMAC300
what is pressure? did you scan for codes. if hti sis tbi did you check for soft hose going to map sensor or blown gasket under tbi unit?
Apr 20, 2013 at 1:50 AM
MPLSBADBOYZ
MEMBER
how do I check for codes in an 94 Chevy Suburban 350
Apr 20, 2013 at 2:00 AM
HMAC300
cross A & B on the aldl with a paper clip turn key on an dwatch light flashes, light will flash three times twice like once then twice =12 get allcodes and come back to site look under OBD1 diagnostics. code 12 is normal with key on and engine not running.check fuel pressure it should 9-11 psi for tbi.
